Przeszukaj pomoc
Unikaj oszustw związanych z pomocą.Nigdy nie będziemy prosić Cię o dzwonienie na numer telefonu, wysyłanie SMS-ów ani o udostępnianie danych osobowych. Zgłoś podejrzaną aktywność, korzystając z opcji „Zgłoś nadużycie”.
Więcej informacji
Adjusting Length of Web History
  • 4 odpowiedzi
  • 11 osób ma ten problem
  • 2 wyświetlenia
  • Ostatnia odpowiedź od Mark L. Storm
I can't figure out how to adjust how long my web history is kept. It seems to be on a default setting of current month + past month. I would like to maintain it for current month + past year. Any advice?
Wszystkie odpowiedzi (4)
  1. There is no longer a user-settable time limit setting in Firefox 4 and newer versions for History. You can not set how long to retain History after Firefox 3.6.x.
  2. Firefox determines automatically how many pages can be kept without affecting the performance of Firefox based on your system's resources.
  3. You can see the current value via the read-only pref places.history.expiration.transient_max_pages on the about:config page. If you try to reset the value, it will automatically reset to the best calculated value so as to not degrade Firefox's performance.
  4. You can reset the no longer used browser.history_expire_days* preferences from older Firefox versions to remove them on the next start.
See --> http://blog.bonardo.net/2010/01/20/places-got-async-expiration
If this reply solves your problem, please click "Solved It" next to this reply when signed-in to the forum.
Not related to your question, but...
You may need to update some plug-ins. Check your plug-ins and update as necessary:
Zmodyfikowany przez SafeBrowser w dniu
If you keep losing older history then see if you have cleanup software running that removes that history on a scheduled base.
Unfortunately or not, I upgraded a while back to v 9.0, so I suppose I'm stuck with the automatic feature. (Ideally, I would like to save 12 months plus current month.) If I increase my cache space, will more history be saved? If not, is there any way to export or save history?
Naw, thanks, but already thought of that.
